01-06-2016 03:53 AM - edited 03-08-2019 03:18 AM
a customer has 50 servers and wants to connect them to the network through 10G Copper . i found that it can be done through CAT6A cable and connect the servers to a nexus 3172 switch but the Problem is how can i connect the 40G uplinks of the nexus to a switch like 4500-6500-6800-3850
Solved! Go to Solution.
01-08-2016 05:04 AM
Cisco's data sheet claims "Up to 20x 40 Gigabit Ethernet ports" on the 6880-X
01-07-2016 10:04 PM
You can get a 40Gb to 4 x 10Gb cable, and then you can plug into ordinary 10Gbe ports.
You can get 40Gbe ports on the 6880. I *think* there is a 3850 model now with 40Gbe ports - but if you are serious about aggregated 40Gbe links I would be going straight for a 6880.
01-08-2016 04:47 AM
Thanks a lot for your reply but the problem is that 40Gb to 4 x 10Gb cable is not compatible with 3850 with the 40GBE
there is no 40G ports on 6880
01-08-2016 05:04 AM
01-08-2016 11:12 AM
If you use the 40GB to 4 x 10Gb cable on your Nexus switch you can then plug the 10Gb ends into your Cisco 3850. You just need to get the 10Gbe module for the 3850.
01-08-2016 11:38 AM
This is cable isnot compatible with 3850 series
01-08-2016 11:44 AM
What about if you use the C3850-NM-2-40G module?
Search for 3850.
It also looks to me like the Nexus 40Gbe to 4 x 10Gbe passive cables are supported (as you can plug the 10Gbe ends into the 3850 10Gbe ports) - but I'll defer to your knowledge.
01-09-2016 03:20 AM
what is the difference between QSFP-H40G-CU1M= and QSFP-4SFP10G-CU1M=
01-09-2016 10:43 AM
QSFP-H40G-CU1M
Cisco 40GBASE-CR4 QSFP+ passive direct-attach copper transceiver module assembly, 1 meter
Sounds like a 40GB to 40Gbe cable.
QSFP-4SFP10G-CU1M
Cisco 40GBASE-CR4 QSFP+ to 4 10GBASE-CU SFP+ passive direct-attach copper transceiver assembly, 1 meter
Sounds like a 40Gbe to 4 x 10Gbe cable.
01-09-2016 01:03 PM
Special Thanks
