How to connect to standby vss switch 4500-x
milad.eslahchi
Hello
We have two 4500-x which are VSS with each other. how can I connect to standby switch from active switch? I already tried "remote login module 2" command but I get this message: Feature not supported on module 2 . I also tried "attach" command which the same message appeared.
I don't want to connect to standby switch via console cable nor recovery IP address.
Mark Malone
Try this
remote login standby
or
remote login switch-id x
CraigKnisley
Ran into this and Google wasn't any help, found this post.
Do a show inventory, look for switch 2, then virtual slot XX.
Then do remote login module XX.
Thanks CraigKnisley.
