how to connect two switches
rdrisaldi
I have to switches one in L3 an the other in L2. Several vlans on the network.
Should i use a trunk connection between them or a etherchannel o port channel?
what is the best way and when to use this options?
thanks in advance for your answer.
Yes,
If you have only one interface for uplink, you need to configure it as a trunk (If you have multiple VLAN’s in your environment).
Something like this (is a minimal config):
interface GigabitEthernet1/0/24
switchport trunk allowed vlan 10,20,30,40,50
switchport mode trunk
Samuel Petrescu
6 Replies 6
Samuel Petrescu
Usually I use etherchaneel configured as a trunk.
For example, if interfaces GigabitEthernet1/0/20 – GigabitEthernet1/0/24 are used to interconnect the switches:
interface range GigabitEthernet1/0/20 - 24
switchport trunk allowed vlan 10,20,30,40,90,99
channel-group 1 mode active
Samuel, thanks for your reply.
If there is only one interface to interconnect the switches I can't use EtherChannel or PortChannel, am I right?
The only solution is to configure that port in trunk mode, is that right?
thanks!
Vivek Ganapathi
Level 4
Level 4
1) Better to always have an etherchannel, this helps you to be redundant on Layer 1.
2) Configure all your Layer 3 VLAN on the L3 switches
3) Configure the trunk interface as suggested By Samuel on both sides
4) Configure your L2 switch in VTP client mode initially to let VTP propagate the VLAN information to your switch & then hardcode it to VTP transparent.
Vivek
Vivek thanks for your reply.
I believe that switches 300 series doesn't have VTP. So I can't use it and should configure all switches.
thanks!
Yes,
Samuel Petrescu
Vivek and Samuel thanks for your help!
