How to Create Trunk Between Cisco Catalyst-3560-CX Series Switch & HP Procurve 2510-48 Switch
Hello Everyone,
Would you'll please look into this query and help me out.
I want to configure trunk between Cisco Catalyst-3560-CX Series Switch (Layer 3 Switch) which has 12 Gigabit ethernet ports & HP Procurve 2510-48 Switch (Layer 2 Switch) which has 48 Fast ethernet ports. Both are manageable switch. However cisco is Gigabit ethernet and HP is Fast ethernet. I have 6 VLANs on cisco switch. I want to create trunk between Cisco and HP switch. I dont want to create VLANs on HP switch. I just want to trunk between them without creating VLANs on HP switch. How to verify if trunk is working fine after configuration.
Please let me know what to configure on both the switches. Please share the configurations on both the switches and i"ll let you'll know if it works or not.
10 Replies 10
Mark Malone
Can give you the Cisco side someone who knows HP can answer that bit ,although I did see this in Google you could try
https://community.spiceworks.com/topic/153622-how-to-configure-trunk-port-between-hp-and-cisco-switches
Cisco
The allowed line is optional to lock down your vlans
interface GigabitEthernet0/47
 description xxxxxxxxxx
 switchport trunk allowed vlan x,x,x,x
 switchport mode trunk
To check if trunk is working use
show in trunk
I made the following configurations on Cisco Switch and HP Switch
CISCO SWITCH
Switch-1>en
Switch-1#config t
Enter configuration commands, one per line. End with CNTL/Z.
Switch-1(config)#int g0/14
Switch-1(config-if)#switchport trunk native vlan 1
Switch-1(config-if)#switchport mode trunk
Switch-1(config-if)#switchport nonegotiate
Switch-1(config-if)#no shut
Switch-1(config)# no cdp enable
However this command "Switch-1(config-if)#switchport trunk encapsulation dot1q" is not working/invalid on this switch. As when i see trunk info by using "sh int trunk" i get below details. So encapsulation dot1q is enabled by default when you enable trunk.
Switch-1#sh int trunk
Port                           Mode    Encapsulation    Status          Native vlan
Gi0/14                         on           802.1q           trunking             1
Port                           Vlans allowed on trunk
Gi0/14                       1-4094
Port                           Vlans allowed and active in management domain
Gi0/14                       1,100-105
Port                            Vlans in spanning tree forwarding state and not pruned
Gi0/14                        1,100-105
HP SWITCH
ProCurve Switch 2510-48# config t
ProCurve Switch 2510-48(config)# int 14
ProCurve Switch 2510-48(eth-14)# enable
ProCurve Switch 2510-48(eth-14)# trunk 14 trk1
ProCurve Switch 2510-48(eth-14)# exit
ProCurve Switch 2510-48(config)# vlan 100
ProCurve Switch 2510-48(vlan-100)# tagged trk1
ProCurve Switch 2510-48(vlan-100)# exit
ProCurve Switch 2510-48(config)# vlan 101
ProCurve Switch 2510-48(vlan-101)# tagged trk1
ProCurve Switch 2510-48(vlan-101)# exit
ProCurve Switch 2510-48(config)# vlan 102
ProCurve Switch 2510-48(vlan-102)# tagged trk1
ProCurve Switch 2510-48(vlan-102)# exit
ProCurve Switch 2510-48(config)# vlan 103
ProCurve Switch 2510-48(vlan-103)# tagged trk1
ProCurve Switch 2510-48(vlan-103)# exit
ProCurve Switch 2510-48(config)# vlan 104
ProCurve Switch 2510-48(vlan-104)# tagged trk1
ProCurve Switch 2510-48(vlan-104)# exit
ProCurve Switch 2510-48(config)# vlan 105
ProCurve Switch 2510-48(vlan-105)# tagged trk1
ProCurve Switch 2510-48(vlan-105)# exit
ProCurve Switch 2510-48(config)# no cdp enable all
When i see trunk info, i get the following
ProCurve Switch 2510-48# sh trunk
Load Balancing
Port | Name              Type |           Group         Type
14 |                   10/100TX |            Trk1           Trunk
When i see VLAN info, i get the following info
ProCurve Switch 2510-48# sh vlan
Status and Counters - VLAN Information
Maximum VLANs to support : 8
Primary VLAN : DEFAULT_VLAN
Management VLAN :
VLAN ID       Name                            Status     Voice
1             DEFAULT_VLAN               Port-based No
100           VLAN100                         Port-based No
101           VLAN101                         Port-based No
102           VLAN102                         Port-based No
103           VLAN103                         Port-based No
104           VLAN104                         Port-based No
105           VLAN105                         Port-based No
cisco side is fine , trunk is up and operational and allowing 6 vlans , through
you only need the encapsulation command on certain platforms that's why I provided it just in case
Encapsulation dot1q is enabled by default on cisco switch when trunk port is enabled.
With the given above configuration i can reach to gateway only on cisco switch side not beyond the HP switch, and from HP switch side i cannot even ping Gateway.
What can i do now?
have you setup default gateway and vlans etc on the HP switch
Nope. I havent setup default Gateway on HP switch but i havent even configured default gateway on cisco switch but it can still ping to gateway from host but not to host which is connected to HP switch. I dont want to create VLANs on HP switch as it was created on cisco switch.
well your vlans are there they must have added automatically as the extract you posted shows vlans from the HP side
every layer 2 switch should have a default gateway for return traffic
if its acting layer 3 you set a default route instead
I am getting following output on cisco switche, what can i do now so that the trunk will start working
Switch-1#sh ip int brief
Interface              IP-Address             OK? Method Status                Protocol
Vlan1                      10.10.0.1             YES NVRAM  up                    up
Vlan100                    10.10.1.1           YES NVRAM  up                    up
Vlan101                    10.10.2.1           YES NVRAM  up                    up
Vlan102                    10.10.3.1           YES NVRAM  up                    up
Vlan103                    10.10.4.1           YES NVRAM  up                    up
Vlan104                    10.10.5.1           YES NVRAM  up                    up
Vlan105                    10.10.6.1           YES NVRAM  up                    up
GigabitEthernet0/1    unassigned       YES unset  down                  down
GigabitEthernet0/2    unassigned       YES unset  down                  down
GigabitEthernet0/3    unassigned       YES unset  down                  down
GigabitEthernet0/4    unassigned       YES unset  down                  down
GigabitEthernet0/5    unassigned       YES unset  down                  down
GigabitEthernet0/6    unassigned       YES unset  down                  down
GigabitEthernet0/7    unassigned       YES unset  up                       up
GigabitEthernet0/8    unassigned       YES unset  down                  down
GigabitEthernet0/9    unassigned       YES unset  down                  down
GigabitEthernet0/10    unassigned     YES unset  down                 down
GigabitEthernet0/11    unassigned     YES unset  down                 down
GigabitEthernet0/12    unassigned     YES unset  down                 down
GigabitEthernet0/13    unassigned     YES unset  down                 down
GigabitEthernet0/14    unassigned     YES unset  up                      up
GigabitEthernet0/15    unassigned     YES unset  down                  down
GigabitEthernet0/16    unassigned     YES unset  down                  down
Switch-1#show int gi0/14
GigabitEthernet0/14 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0056.2bc9.2a0e (bia 0056.2bc9.2a0e)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive not set
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 2000 bits/sec, 3 packets/sec
    93 packets input, 15974 bytes, 0 no buffer
    Received 93 broadcasts (84 multicasts)
    0 watchdog, 84 multicast, 0 pause input
    1494 packets output, 122772 bytes, 0 underruns
    0 output errors, 0 collisions, 1 interface resets
    0 unknown protocol drops
    0 lost carrier, 0 no carrier, 0 pause output
I made the following changes to the configuration on cisco switch and obtained this outputs -
But still no luck, as the trunk is not working
Switch-1(config-if)#speed auto
Switch-1(config-if)#duplex full
Switch-1(config-if)#flowcontrol receive on
Switch-1(config-if)#no cdp enable
Switch-1(config-if)#channel-group 1 mode on
Switch-1(config-if)#channel-group 1 mode active
Switch-1(config-if)#exit
Switch-1#sh vlan brief
VLAN Name Status Ports
1 default active Gi0/1, Gi0/2, Gi0/3, Gi0/4
Gi0/11, Gi0/12, Gi0/13, Gi0/14
Gi0/15, Gi0/16
100 Senior Mgmt active Gi0/5
101 ConferenceRoom active Gi0/6
102 MICM Users Admin active Gi0/7
103 Classrooms active Gi0/8
104 ETTI College active Gi0/9
105 ComputerLab active Gi0/10
1002 fddi-default act/unsup
1003 trcrf-default act/unsup
1004 fddinet-default act/unsup
1005 trbrf-default act/unsup
Switch-1#show log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 60 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 60 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 62 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (4096 bytes):
17 10:46:49.681: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/14, changed state to up
Feb 17 10:47:18.685: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
Feb 17 10:47:18.685: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan100, changed state to up
Feb 17 10:47:18.688: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan101, changed state to up
Feb 17 10:47:18.709: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan102, changed state to up
Feb 17 10:47:18.709: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan103, changed state to up
Feb 17 10:47:18.709: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan104, changed state to up
Feb 17 10:47:18.713: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan105, changed state to up
Feb 17 10:48:15.364: %SYS-5-CONFIG_I: Configured from console by console
Feb 17 10:50:26.387: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Feb 17 10:50:26.390: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan100, changed state to down
Feb 17 10:50:26.390: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan101, changed state to down
Feb 17 10:50:26.390: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan102, changed state to down
Feb 17 10:50:26.394: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan103, changed state to down
Feb 17 10:50:26.394: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan104, changed state to down
Feb 17 10:50:26.394: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan105, changed state to down
Feb 17 10:50:27.372: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/14, changed state to down
Feb 17 10:50:29.389: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/14, changed state to up
Feb 17 10:50:58.033: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
Feb 17 10:50:58.036: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan100, changed state to up
Feb 17 10:50:58.036: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan101, changed state to up
Feb 17 10:50:58.036: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan102, changed state to up
Feb 17 10:50:58.040: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan103, changed state to up
Feb 17 10:50:58.040: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan104, changed state to up
Feb 17 10:50:58.043: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan105, changed state to up
Feb 17 10:51:39.095: %SYS-5-CONFIG_I: Configured from console by console
Feb 17 10:52:43.876: %EC-5-CANNOT_BUNDLE2: Gi0/14 is not compatible with Po1 and will be suspended (flow control receive of Gi0/14 is on, Po1 is off)
Feb 17 10:52:43.887: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Feb 17 10:52:43.887: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan100, changed state to down
Feb 17 10:52:43.890: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan101, changed state to down
Feb 17 10:52:43.890: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan102, changed state to down
Feb 17 10:52:43.890: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan103, changed state to down
Feb 17 10:52:43.890: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan104, changed state to down
Feb 17 10:52:43.894: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan105, changed state to down
Feb 17 10:52:44.869: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/14, changed state to down
Feb 17 10:53:33.292: %EC-5-CANNOT_BUNDLE2: Gi0/14 is not compatible with Po1 and will be suspended (flow control receive of Gi0/14 is on, Po1 is off)
Feb 17 10:54:07.717: %EC-5-CANNOT_BUNDLE2: Gi0/14 is not compatible with Po1 and will be suspended (flow control receive of Gi0/14 is on, Po1 is off)
Feb 17 10:54:09.391: %EC-5-CANNOT_BUNDLE2: Gi0/14 is not compatible with Po1 and will be suspended (flow control receive of Gi0/14 is on, Po1 is off)
Feb 17 10:54:37.517: %SYS-5-CONFIG_I: Configured from console by console
Feb 17 10:56:39.281: %SYS-5-CONFIG_I: Configured from console by console
Switch-1#
For cisco 3560 please follow this Guide:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/software/release/12-2_52_se/configuration/guide/3560scg/swpvlan.html
For HP please refer to the following links:
https://community.hpe.com/t5/Switches-Hubs-and-Modems/Connecting-HP-Procurve-to-Cisco-3560/td-p/4300209
http://whp-hou4.cold.extweb.hp.com/pub/networking/software/2510-MgmtCfg-July2007-59914761.pdf
