how to create vlan on cisco switch 3560G and do routing
malai.joseph
I am a new to cisco but managed to add ip address and default gateway to cisco switch and able to check via telnet
I  have 3 cisco switch and i want to setup vlan and all vlan should be  able to reach vlan8 as on picture attached and NATting is done on  pfsense
---opensource
Initial i have 192.168.3.1 gateway and mask 255.255.255.0 on pfsense,and the rest i mean 192.168.3.2-192.168.3.254 on network
Now i want to have vlan started to subnet as attached
pls give the way forward how to go on each cisco switch,cause all servers and cisco switch belong to vlan8
Thx
Shashank Singh
Hi Joseph,
To create vlan 8 on the switch:
switch# conf t
switch(conf)# vlan 8
switch(conf)# exit
To assign ip address on interface vlan 8 on the switch:
switch# conf t
switch(conf)# int vlan 8
switch(conf-int)# ip address 192.168.3.129 255.255.254.0
switch(conf)# end
To assign L2 portson the switch to vlan 8:
switch# conf t
switch(conf)# int gi0/1
switch(conf-int)# switchport mode access
switch(conf-int)#switchport access vlan 8
switch(conf)# end
Following this you can connect a PC on gi0/1 and assign an IP address in the vlan 8 range as mentioned in your diagram. The default gateway on the PC will be IP address if interface vlan 8 (192.168.3.129)
Similarly configure other switches also. For more info visit:
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_configuration_example09186a008009478e.shtml
Hope this helps,
Shashank
P.S. Please rate if this helps answer your question
10 Replies 10
Shashank Singh
Hi Joseph,
switch# conf t
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# end
Hope this helps,
Shashank
Thanks for quick reply...thx very much
i managed to conf all vlan2-8 and its working when pinging its gateway ,from all 3 switch
connect switch to switch by
go to interface g0/27
switchport mode trunk
switchport trunk allowed vlan2,vlan3 ...
now the problem is
1.how to make one vlan say vlan2 reach vlan 8 and viceversa?
2.how to make vlan say vlan3 reach internet? thru pfsense as gateway with ip 192.168.3.1/24
3.is it posible to leave pfsense with ip 192.168.3.1/24? used for natting
4.am i right to put ip range of vlan 8 on all cisco switch and servers?
5.how to route all vlan to internet
6.is my subnetting correct...each vlan has at least 48 users?   192.168.3.0/23
thx
joseph
Hi Joseph,
Intervlan routing on the 3560 switch will work once you configure:
switch(conf)# ip routing
3560 does not support NAT, so you will have to use another router that can do natting for you. Just trunk all your vlans to the router and make sure that the default route on the 3560 points to the correct IP address, and that the subnet address matches the Internet gateway router.
Cheers,
Shashank
Please rate helpful posts
Thx again
Pls elaborate on this
1.Did u mean default route on 3560 for all 3 cisco switch? or the one connected to router
2.the ip address of cisco switch connected to router must have same range?
3.do i need to do ip routing on all cisco switch
4.if no4 is yes then how to controll broadcast from vlan say 1 to get to vlan 4
thx again
Joseph
Hi Shashank,
Thanks for help
Today I got new cisco router 1900 series and i do know how to conf ,
to go internet,i  mean to do NAT, and below is plannned conf on 3 cisco switch  named A,B,C
kindly have a look at To assign trunk from A-cisco switch(fiber connect to port 26) to B-cisco switch and A-cisco switch(fiber connect to port 27) to C-cisco switch if am correct,if not pls correct me
Do i need to put different ip range for 3 cisco switch for management and router?
Do i need to do ip routing on each cisco switch?
how to make all vlan reach vlan 8
thx and sorry for inconvinience
any suggestion ,much appreciated
joseph
Conf on B-cisco switch 3560G
To create vlan 2 on the switch:
switch# conf t
switch(conf)# vlan 2 name DCE
switch(conf)# exit
To assign ip address on interface vlan 2 on the switch:
switch# conf t
switch(conf)# int vlan 2
switch(conf-int)# ip address 192.168.2.1 255.255.254.0
switch(conf)# end
To assign L2 ports on the switch to vlan 2,port1 and port 2 go to vlan2
switch# conf t
switch(conf)# int gi0/1-2
switch(conf-int)#description Link to vlan 2
switch(conf-int)#switchport access vlan 2
switch(conf)# end
To create vlan 3 on the switch:
switch# conf t
switch(conf)# vlan 3 name DAHR
switch(conf)# exit
To assign ip address on interface vlan 3 on the switch:
switch# conf t
switch(conf)# int vlan 3
switch(conf-int)# ip address 192.168.2.65 255.255.254.0
switch(conf)# end
To assign L2 ports on the switch to vlan 3,port 3,port 4 and port 5 go to vlan3
switch# conf t
switch(conf)# int gi0/3-5
switch(conf-int)#description Link to vlan 3
switch(conf-int)#switchport access vlan 3
switch(conf)# end
To create vlan 4 on the switch:
switch# conf t
switch(conf)# vlan 4 name DRCS
switch(conf)# exit
To assign ip address on interface vlan 4 on the switch:
switch# conf t
switch(conf)# int vlan 4
switch(conf-int)# ip address 192.168.2.129 255.255.254.0
switch(conf)# end
To assign L2 ports on the switch to vlan 4,port 6 and port 7 go to vlan4
switch# conf t
switch(conf)# int gi0/6-7
switch(conf-int)#description Link to vlan 4
switch(conf-int)#switchport access vlan 4
switch(conf)# end
To create vlan 5 on the switch:
switch# conf t
switch(conf)# vlan 5 name DOI
switch(conf)# exit
To assign ip address on interface vlan 5 on the switch:
switch# conf t
switch(conf)# int vlan 5
switch(conf-int)# ip address 192.168.2.193 255.255.254.0
switch(conf)# end
To assign L2 ports on the switch to vlan 5,port 8 and port 9 go to vlan5
switch# conf t
switch(conf)# int gi0/8-9
switch(conf-int)#description Link to vlan 5
switch(conf-int)#switchport access vlan 5
switch(conf)# end
To assign trunk from B-cisco switch(fiber connect to port 27) to A-cisco switch
switch# conf t
switch(conf)# int gi0/27
switch(conf-int)#switchport mode trunk
switch(conf-int)#switchport trunk allowed vlan2,vlan3,vlan4,vlan5
Conf on C-cisco switch 3560G
To create vlan 7 on the switch:
switch# conf t
switch(conf)# vlan 7 name PMU
switch(conf)# exit
To assign ip address on interface vlan 7 on the switch:
switch# conf t
switch(conf)# int vlan 7
switch(conf-int)# ip address 192.168.3.65 255.255.254.0
switch(conf)# end
To assign L2 ports on the switch to vlan 7,port1-24 go to vlan7
switch# conf t
switch(conf)# int gi0/1-24
switch(conf-int)#description Link to vlan 7
switch(conf-int)#switchport access vlan 7
switch(conf)# end
To assign trunk from C-cisco switch(fiber connect to port 25) to A-cisco switch
switch# conf t
switch(conf)# int gi0/25
switch(conf-int)#switchport trunk allowed vlan7
Conf on A-cisco switch 3560G
To create vlan 6 on the switch:
switch# conf t
switch(conf)# vlan 6 name MIS
switch(conf)# exit
To assign ip address on interface vlan 6 on the switch:
switch# conf t
switch(conf)# int vlan 6
switch(conf-int)# ip address 192.168.3.1 255.255.254.0
switch(conf)# end
To assign L2 ports on the switch to vlan 6,port1-12 go to vlan6
switch# conf t
switch(conf)# int gi0/1-12
switch(conf-int)#description Link to vlan 6
switch(conf-int)#switchport access vlan 6
switch(conf)# end
switch# conf t
switch(conf)# int gi0/26
switch(conf-int)#switchport trunk allowed vlan6
switch(conf)# end
switch# conf t
Hi Joseph,
The configurations are absolutely fine with a few minor corrections:
switch(conf)# vlan 2 name DCE ----> this needs to be done as below
switch(conf-vlan)#name DCE
switch# conf t
switch(conf)# int gi0/1-2  ----->>> int range gi0/1-2
switch(conf-int)#switchport trunk allowed vlan2,vlan3,vlan4,vlan5 ---->> switchport trunk allowed vlan 2,3,4,5
You will need to configure all the vlans (2,3,4,5,6,7) on switch A. This is because when switch B will send a packet to switch A on vlan 2, it will be dot1Q tagged with a vlan 2 tag while leaving switch B. When this packet will arrive on switch A, the tag will be examined and the packet is sent to the interface in corresponding vlan on switch A. As switch A will not have vlan 2 configured, the packet will not be sent further.
Hence, it is advisable to create all the vlans on on three switches, so tha the switch understands the tag on the packet. Do not assign interfaces to those vlans if not needed.
IP Routing on switches will make them do intervlan routing. You need to enable this on the switches that you wish to be able to route packets between vlans.
Hope this helps,
Shashank
Please rate if this helped answer your question
Thanks Shashank for your support
Thanks for correction
Sorry and pls help on below request,so i can go and implement
1.Did u mean i need to put all vlan on each switch? as below conf shown
2.Do not assign interfaces to those vlans if not needed.?how to do this pls?
3.What to do on cisco router1900 to access internet in replacing pfsense pls?how to conf
4.Do i need separate ip range for cisco and router for management?
5. is the part correct pls?
switch# conf t
switch(conf)# end
switch# conf t
thx again
joseph
switch# conf t
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# int range gi0/1-2
switch(conf)# end
switch# conf t
switch(conf-vlan)#name DAHR
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# int range gi0/3-5
switch(conf)# end
switch# conf t
switch(conf-vlan)#name DRCS
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# int range gi0/6-7
switch(conf)# end
switch# conf t
switch(conf-vlan)#name DOI
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# int range gi0/8-9
switch(conf)# end
switch# conf t
switch(conf-vlan)# name MIS
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# int range gi0/1-12
switch(conf)# end
switch# conf t
switch(conf-vlan)#name PMU
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# int range gi0/1-24
switch(conf)# end
switch# conf t
switch(conf-int)#switchport trunk allowed vlan2,3,4,5
switch# conf t
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# end
switch# conf t
switch# conf t
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# exit
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# end
switch# conf t
switch(conf)# end
switch# conf t
if the ip default gateways for each vlan are the SVIs on the 3550switch connected to your router then to get to internet
I would simply put on the 3550 the command  ip default-gateway x.x.x.x where x.x.x.x is ip address of router's interface connected to switch and on the router I would put a static route pointing to next hop(ISP router) if there isn't already one given with dhcp by ISP.
Regards.
Alain.
Thanks Alain
First Do i need to put all vlan on 3 switch,say vlan 1-8 on switch A,and on switch B and on switch C?
Do i need to do ip routing command on each switch?
Do i need to assign ip address default gateway on each switch?if yes suppose to be on the same ip range?
Is there are need for adding vlan on router?pls help
J
Hi Shashank,
Now i have a cisco router 1921 instead of pfsense,pls help on how trunk all
vlan on cisco router so they can all broswe internet
I mean what need to be done on cisco router to access internet and one vlan
talk to other
thanks
J
On Wed, Feb 9, 2011 at 3:21 PM, shashasi <
