Need Basic IOS Help with DHCP Pool Configuration
jaesposito
Level 4
Level 4
I would like to ensure that one of my DHCP clients gets the same IP Address every time.  I'm not 100% sure on how to implement this configuration on my Cisco 831 router running IOS version 12.4.
Here is my existing DHCP configuration:
ip dhcp excluded-address 10.10.10.1
ip dhcp pool CLIENT
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   lease 0 2
Here is the MAC address of the client of interest:
0160.eb69.426f.59
I would like the client to receive IP address 10.10.10.249 everytime.
Can you tell me what configuration changes to make?  Thank you very much!
James
cadet alain
plug in the client and when it gets an IP with dhcp then  do a sh ip dhcp bindings  on the router.
take note of client-identifier, if it is 12 chars then use the hardware-address command otherwise if it's 14 chars beginning with 01 then
use the client-identifier command in your static pool.
For the pool:
ip dhcp pool static-pool
host  10.10.10.249 255.255.255.0
hardware-address| client-identifier xxxxxxxxx
It will derive other options from parent pool CLIENT.
Regards.
Alain.
cadet alain
For the pool:
Regards.
Alain.
Alain,
Thank you!  I will do that.
How do I update the configuration if I decide that I want to do this with a second machine?
I appreciate the help!
James
You create another manual binding(static) pool for the other machine, igf it's the same OS it will use the same identifier(mac address or client-identifier).
take a look here :http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfdhcp.html#wp1001108
Regards.
Alain.
