How to create VLANs in the WebUI for 3750X?
Inxsible
I have a cisco 3750X switch and i upgraded it to the latest IOS : 15.2(4)E10)
I set up the switch IP address and now am presented with the WebUI below:
Cisco 3750X WebUICisco 3750X WebUI
How would I go about creating and managing VLANs in the WebUI? Did I install the wrong IOS?
Thanks for your help in advance !!
pieterh
have not done this on 3750X models, but I have some suggestions to check
- first try the configure -> port settings
   I guess you'' find an option to modify the port to trunk mode and create vlans there
- evenso click on a port in the  status-image, a window may pop-up
- last:  for more advanced configuration start network assistant
Thanks for your reply @pieterh .
The Configure -> Port Settings simply allows setting the Speed, Duplex and POE for each port.
  1. Speed is an option between Auto, 10, 100 & 1000
  2. Duplex options are Auto, Full & Half.
  3. POE options are Auto & Never
On the status image, when hovering over a port, it just gives general info -- description, Status and whether POE is on or off. No pop up window when clicking on it.
Network Assistant is a Windows & Mac only option. I have neither in my network and wouldn't want to buy/maintain one just to maintain a switch.
Seems like CLI is the only way to do it. I wonder why they even have a WebUI interface for the 3750X
