How to deploy 1 gigabit in Catalyst 4500X
Hi All,
I hope you can help me, im currenly configuring a 4500X with 16 port. All sfp are 1Gig, but when I input show ip int brief, it shows that the interfaces are on 10 Gig. Does Catalyst 4500X already support the 1Gig SFP without inputting a command or do I have to configure it to activate the 1Gig interface?
Jackie Gabriel
Steve Fuller
Level 9
Level 9
The switch should just recognise the port is using a 1GE SFP and run at the appropriate speed. The following is from my switch running IOS-XE 03.03.02.
As you'll see the show ip interface brief still names the interfaces as TenGigabitEthernetX/Y, but the SFP in Te1/9 is recognised as a GE SFP and operates at that speed. Also from the show run int te1/9 you can see there are no specific commands added for speed.
ocs4516x-1#sh ip int brie
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet1          unassigned      YES unset  down                  down
TenGigabitEthernet1/1  192.168.71.2    YES manual up                    up
TenGigabitEthernet1/9  unassigned      YES unset  up                    up
ocs4516x-1#sh inventory
NAME: "TenGigabitEthernet1/9", DESCR: "1000BaseSX"
PID: GLC-SX-MMD        , VID: V01  , SN: FNS164400TK
ocs4516x-1#sh int te1/9
TenGigabitEthernet1/9 is up, line protocol is up (connected)
  Hardware is Ten Gigabit Ethernet Port, address is 6c20.56c5.2e98 (bia 6c20.56c5.2e98)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX
  input flow-control is off, output flow-control is off
ocs4516x-1#sh run int te1/9
Building configuration...
Current configuration : 100 bytes
interface TenGigabitEthernet1/9
switchport trunk allowed vlan 11,111
switchport mode trunk
end
6 Replies 6
Steve Fuller
Level 9
Level 9
end
Steve,
Thanks for the info!
Wow, you have to do a "sh int tex/x" to see a 1Gig SFP?
Who came up with this type of design?
Reza
Hi Steve,
Thank you for your explanation. It really helped me a lot. But I hope the developers of 4500-X will also change the the show ip int brief display with respect to the SFP since the port is auto-detect. Just to avoid confusion.
Jackie Gabriel
Leo Laohoo
I agree.  The port will determine the type of SFP you use.
InayathUlla Sharieff
Hi Jackie,
I am not sure if this is what you are looking for:
Try this out:
4506-E(config)#hw-module module 1 port-group 2 select ?
 gigabitethernet     Select this port-group's gigabit interfaces
 tengigabitethernet  Select this port-group's 10G interfaces
(Eg: 4506-E(config) #hw-module module 1 port-group 1/2 select gigabitethernet )
So after entering this command you will have all the ports trun into gig bit rather than 10 gig.
Inayath.
Hi Inayath,
I tried that command but it is not supported on 4500-X.
Thanks.
