HOW TO DISABLE AUTO-NEGOTIATION CISCO N9K-C9336C-FX2 10G SWITCHPORT
GIBassment1
Looking for recommendations as we have a compatibility issue with an AMD U200 40G card which is broken out to 4x SFP+ connections and then a QNA into a Cisco QSFP+ on the C9336C-FX2 switch.
We are trying to disable auto-negotiation on the Cisco switch and get following error;
HDCI-NSWDDNGDF01C# show int eth1/15 | i Auto-N
  Auto-Negotiation is turned on  FEC mode is Auto
HDCI-NSWDDNGDF01C(config-if)# no negotiate auto
ERROR: cannot turn off auto-negotiate at 10G speed
The u200 card is proprietary code and they can't enable Auto-negotiation, so we have seeing unstable L2 in the network between these devices.
Any way to disable the auto-neg on the cisco side?
Thank-You for any guidance!
balaji.bandi
Instead of no negotiation, setup the speed and check (like hardcode speed) especially nexus devices.
BB
GIBassment1
Hello BB,
Thanks for your quick reply! Just to clarify what you have recommended, is this what you are suggesting?
Here is the switchport config;
interface Ethernet1/15
  description M::US22727I-ORTD61B_clx0p1
  no cdp enable
  switchport
  switchport access vlan 582
  spanning-tree port type edge trunk
  no snmp trap link-status
  speed 10000
  duplex full
  storm-control broadcast level 5.00
  no shutdown
GIBassment1
Additional piece of information, when this L2 event occurs the MAC address from the Server (AMD U200 Card>SFP 10G Breakout>QNA>9336 QSFP+ Switchport) the Cisco doesn't report the MAC address in the connection for that link.
No MAC Address detected on Eth1/25 even if I can see the link from the switch showing as UP.
issue is that US22727I-ORTD64B_clx1p1_(clx4) not coming up after cold boot.
Here are the MAC addresses I am seeing for all connections into 64B:
HDCI-NSWDDNGDF01C#
Eth1/24       M::US22727I-ORTD64 connected trunk     full    10G     10Gbase-SR
Eth1/25       M::US22727I-ORTD64 connected trunk     full    10G     10Gbase-SR
Eth1/24       eth    10G     M::US22727I-ORTD64B_clx0p0
Eth1/25       eth    10G     M::US22727I-ORTD64B_clx1p0
*  572     dcae.0411.0480   dynamic  0         F      F    Eth1/24
*  572     dcae.0411.0490   dynamic  0         F      F    Eth1/25
HDCI-NSWDDNGDF01D#
Eth1/24       eth    10G     M::US22727I-ORTD64B_clx0p1
Eth1/25       eth    10G     M::US22727I-ORTD64B_clx1p1
*  582     dcae.0411.0481   dynamic  0         F      F    Eth1/24
