How to disable MACFLAP notification(when clients roaming to another AP) ?
Ethan and Mia
Hi all
I facing some issue about macflapping notification when clients roaming to another AP
A lot of AP on the same a switch. How can I disable it ?
the easiest way to get rid of these messages would be to configure a logging discriminator. Either one of the two below should work:
logging discriminator MACFLAP severity drops 4 facility drops SW_MATH mnemonics drops flapping
logging buffered discriminator MACFLAP 100000
logging console discriminator MACFLAP
logging monitor discriminator MACFLAP
logging host x.x.x.x discriminator MACFLAP
or
logging discriminator MACFLAP msg-body drops flapping
logging monitor discriminator NACFLAP
logging host X.X.X.X discriminator MACFLAP
Hello
you could also try using:
no mac address-table notification mac-move
Also just like to add mac flaps can indeed be a result of wifi hosts roaming but if you a have consistently high number then its time to investigate your network as it may be a loop that’s the root cause.
Whats the cpu/memory utilisation of the switches ?
Kind Regards
Paul
