how to distinguish genuine cisco products to imitation
barnabas11
hi people? I want to buy a cisco switch from a reseller. how do I know if it's original just by looking at it?
Charles Hill
Hey barnabas11,
Look for the serial number and go to
https://cway.cisco.com/sncheck/
and enter the serial number.  This will give you the product ID and if it's covered under warranty(contract # and expiration date of warranty).
If you go to a Cisco partner, you should not have any problems.  At least I would hope not.
John_in_NZ
Good article!  I had not ran into this before.
Learn something new everyday.
(+5)
Pawan Sharma
Best way to avoid any counterfeit product is to request support contract along with it or just ask for the product serial number in advance to buy a support contract for the same, Any Cisco partner should be able to tell you the status of product by serial number.
I always ask for product serial numbers in advance and buy from my trusted cisco partners only.
Pawan Sharma
https://itgears.io
