how to do routing on N7K-F248XP-25E (Nexus 7010) ?
Duc Vu
                   Hi all,
     Please educate me the following scenario : I have Nexus 7010 with 2 L3 modules, N7K-M132XP-12L and N7K-M148GT-11L. Now to increase more ports for end devices, I add in the module N7K-F248XP-25E and believe it's for Layer 2 switching only. Is there a way to do routing on these L2 modules without having to go to the L3 modules ? Thanks for all help.
Leo Laohoo
No.  If you have an M1/M2 card and routing is enabled, the F2E card will "step down" and do Layer 2 work.  All Layer 3 work will be done by the M1/M2 card.
