how to drop packets
hi
in my lan i see valid source IP addresses try to reach a invalid source IP addresses which is not available in the LAN.
for example in my firewall log
Deny inbound UDP from 172.16.1.3/1042 to 172.17.10.3/161 on interface inside
172.16.1.3 is valid but 172.17.10.3 is invalid or non existent
can you help create a acces list or packet drop config in switch so that this packet does not reach the firewall
acampbell
karthikeyan
Use you own names interfaces etc, but something along these lines.
ip access-list extended YOURLIST
deny udp host 172.16.1.3 eq 1042 host 172.17.10.3 eq 161
permit ip any any
interface vlan 16
ip address 172.16.1.1 255.255.255.0
ip access-group YOURLIST in
By the way UDP port is used for SNMP.
Looks like your device is trying to contact an snmp server.
Useful links:-
http://en.wikipedia.org/wiki/List_of_TCP_and_UDP_port_numbers
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml#ipnamacl
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
BTW, an alternative to using an ACL, you might be able to route bad packets to a null interface, which also effectively drops them.
