How to enable debugs to analyse route-map related issues?
dalakshm
And while redistributing, filters are applied through route-map.
Now to analyse, whether routes are getting filtered properly or not, I need to enable route-map debugs and check.
Whats the command to enable it?
I tried
debug route-map event
debug route-map api
debug route-map ipc
Doesnt seems to work.
julian.bendix
Level 7
Level 7
Hi!
So you are using the route-map to manipulate announcements by the routing protocol right?
Did you check what the neighbors regarding the routing protocol are receiving and installing in their routing tables?
I don't think there are debugs for the route-map to see that.
We would need to capture the packets sent by the routing protocol.
Do you know what the neighbors see and if that matches to the config on your side?
Best regards
Julian
