How to enable LLDP on Cisco Catalyst 6500?
jmp780718
Hi All.
How to enable LLDP on Cisco Catalyst 6500?; enable this feature has an impact?
Thank you.
2 Accepted Solutions
Rajeev Sharma
Hey,
Its enabled by default. check the link below:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/power_over_ethernet.html#wp1116393
HTH.
RS.
Hey,
Configure "lldp run" command in global configuration mode to enable it. And i don't believe there are any impacts enabling this feature unless you have too may PoE devices using lldp and less power available in PS unit.
HTH.
RS.
Rajeev Sharma
Hey,
HTH.
RS.
Hi Rajeevsh.
My switch has disable the lldp:
CORE#show lldp neighbors
% LLDP is not enabled
 if i enable this feature has an impact?
Thank you.
Hey,
HTH.
RS.
jmp780718
Hi Rajeevsh.
Thank you.
