how to enable PIM on all active interfaces ?
mohammed hashim
hi,
when the topology is large, then it is inconvenient to go to each interface and enable PIM,
is there a way to enable PIM on all active interfaces of the router?
I checked global command, and did not see this
Hello
My understanding there isn't, even for large MC domains you will still need to configured the routers for MC routing and their respective interfaces if participating in forwarding of MC traffic.
Even in Interdomain multicast routing using MSDP - static peers are still required.
Res
Kind Regards
Paul
