How to Enable Poe function in WS-2960S-24-PSL
thuthu90911
Hi all
                      Please kindly answer to me ,  how to configure Poe enable in 2960s-24psl , i am a new guy . can u please detail answer me how to configuration in to the switch.
So Many Thanks
the PoE ports are enabled by default and set to 'auto', which means the port automatically detects connected devices that are not powered, and supplies the power.
You can change the 'auto' mode by using the 'power inline' interface command:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_44_se/configuration/note/ol14988.html#wp1028704
Thanks you gpauwen :)
Tausif Gaddi
You dont need to enable PoE, please refer
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/hardware/installation/guide_stack/2960SHIG/HIGOVERV.html
