How to enable VLAN Routing
adam.weight
I have a layer 3 Cisco switch (SG300-52) that I am trying to get setup and functioning, but am having problems with getting DHCP to work on multiple VLAN's.
I have 3 vlans (VLAN1 management) VLAN 2 and VLAN 3. I am currently using DHCP on our firewall device which is on VLAN 1. When I connect a computer to a port on VLAN 1, the device is able to pull a DHCP lease from the firewall. If I connect a device to a port on VLAN 2 or 3, it cannot find the firewall to obtain a DHCP lease.
I am assuming this has to do with routing. I believe that VLAN2 and VLAN3 don't know how to get to the firewall on VLAN 1, but I've been looking around for hours and trying different commands to get the routing to work but nothing so far.
Basically what I am looking to do is have 3 VLAN's. DHCP is on VLAN1, and all 3 vlans should be able to pull a DHCP lease from that DHCP server (firewall). I do not however, want the VLAN's communicating with each other in any other way. So basically what I want is the following:
VLAN 1 obtain DHCP from firewall on VLAN1 and access to Internet through firewall on VLAN 1
VLAN 2 obtain DHCP from firewall on VLAN 1 and access to Internet through firewall on VLAN 1 - no other communication with VLAN 1, and no communication with VLAN 3
VLAN 3 obtain DHCP from firewall on VLAN 1 and access to Internet through firewall on VLAN 1 - no other communication with VLAN 1, and no communication with VLAN 2
I can get DHCP to work on all VLAN's if I create a routing policy on my firewall, but then all 3 vlans are able to communicate with each other. For security purposes, this will not work. I need them to pull DHCP without talking to each other.
Any ideas on how I can get this to work? Been working on this for several days with no luck.
Adam.
2 Accepted Solutions
1) for vlan 2 host the default gateway is vlan2 interface Ip and same for vlan3 hosts
2) to filter communication
ip access-list extended VLAN2
deny ip 10.0.108.0 0.0.0.255 10.0.109.0 0.0.0.255
permit ip any any
ip access-list extended VLAN3
deny ip 10.0.109.0 0.0.0.255 10.0.108.0 0.0.0.255
permit ip any any
int vlan2
ip acces-group VLAN2 in
int vlan3
ip access-group VLAN3 in
Alain
ok so I was presuming this was IOS CLI syntax on this model but I was wrong.
to apply the ACL under the interface : service acl-input "name of ACL"  default-action deny-any| permit-any.
Alain
17 Replies 17
acampbell
Adam,
You will need to enable dhcp-relay in oreder for your dhcp discovers etc to cross vlans.
Look at the config guide section 16
http://www.cisco.com/en/US/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
I've already done that. I've enabled DHCP relay on the switch and set the helper address to the DHCP server. Still nothing. The only device that gets an IP address are devices on VLAN 1.
You need the dhcp-relay with the destination ip address of the firewall/dhcp-server.
The firewall will ip routes back the switch layer 3 intefaces (VLAN SVIs) via a next hop of the  switch layer3 (SVI) address on its VLAN1.
Alex.
Yes, and I believe I've done that as well, unless I'm doing something wrong. Basically what happens is I can get DHCP to work if I put a route in the firewall for all 3 vlans pointing to the switch as the next hop. The problem is as soon as I do that, VLAN 2 and VLAN 3 can communicate with each other as well. For security reasons I can't have this happen. I need to be able to route the traffic to DHCP requests without having the VLAN's capable of inner-communication.
My firewall (DHCP Server, and Internet gateway) is 10.0.105.1
Here is the basic config I have right now on the switch.
config-file-header
CSW1
v1.2.9.44 / R750_NIK_1_2_584_002
CLI v1.0
file SSD indicator excluded
vlan database
vlan 2-3
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp relay address 10.0.105.1
ip dhcp relay enable
ip dhcp information option
bonjour interface range vlan 1
hostname DCSW1
username cisco password encrypted 43b085f3d6a61583689378eedbbbc222c32a364b privilege 15
ip name-server  66.28.0.45 66.250.64.15 8.8.8.8
ip telnet server
interface vlan 1
ip address 10.0.105.2 255.255.255.0
no ip address dhcp
interface vlan 2
name Review1
ip address 10.0.108.2 255.255.255.0
interface vlan 3
name Review2
ip address 10.0.109.2 255.255.255.0
interface gigabitethernet1
spanning-tree portfast
switchport mode access
interface gigabitethernet2
switchport access vlan 2
interface gigabitethernet3
switchport access vlan 3
interface gigabitethernet52
spanning-tree guard root
switchport trunk allowed vlan add 2-3
ip helper-address all 10.0.105.1 37 42 49 53 137 138
ip route 0.0.0.0 0.0.0.0 10.0.105.1
Using this as is, computers on VLAN 2 and VLAN 3 do not receive DHCP. If I add the following routes on my firewall:
Source                    Destination                    Service                    Gateway
Any                         10.0.108.0/24                    Any                         10.0.105.2
Any                         10.0.109.0/24                    Any                         10.0.105.2
DCHP then works for VLAN 2 and VLAN 3, but when I run a ping test from a computer on VLAN 2 to a computer on VLAN 3 I receive valid responses. This is not good for security purposes. I want to have VLAN 2 and VLAN 3 have no communication with each other, and have VLAN 2 or VLAN 3 pull DHCP from the firewall, but have no other communication with other devices on VLAN 1.
Am I doing something wrong?
glen.grant
  I'm no FW guy but you are going to have to rules in the FW blocking all traffic on those vlan interfaces except the subnet you want on there .
Yeah, I actually tried that too. I set up rules in the FW to block all traffic between 10.0.108.0 and 10.0.109.0, but it doesn't seem to do anything. Communication still happens even though I specifically put a denial statement in the FW between those two networks.
Hi Adam,
just simply add a host route for each VLAN interface where you have the ip helper-address command configured instead of subnet routes for each of these VLANs.Your DHCP server needs to reply with unicast to the gia address for DHCP relay to work but it doesn't need to route back to the entire VLAN subnet.
Alain
I appologize, I'm still fairly new to Cisco routing. I have done some work but not very much. Can you please explain a bit more?
So you are talking about putting in a static IP route on the Cisco switch itself to route from the DHCP server to the IP of the VLAN?
would it be something like
ip route 10.0.108.2 255.255.255.255 10.0.105.2
I'm still a bit confused I guess. Or were you talking about a route on the firewall pointing to just the IP of the VLAN on the switch rather than the entire vlan subnet?
Thank you for your help, don't know why I didn't think of that earlier.
I made some changes on my firewall and added host routes to point from the DHCP (Firewall) to the Switch for routes just to the IP of the VLAN instead of the whole subnet.
DHCP is working now, but I found two other problems as soon as I did this.
  1. Computers on VLAN 2 and VLAN 3 are pulling DCHP but cannot access the internet. They can see the primary VLAN IP, but cannot reach the firewall (gateway of last resort)
  2. VLAN 2 and VLAN 3 are now communicating with each other (even though no route exists for it) I need them to not communicate with each other.
Problem 1
DCHP is working as you can see:
C:\Users\Adam>ipconfig /all
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit Controller
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   IPv4 Address. . . . . . . . . . . : 10.0.108.216(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Wednesday, October 30, 2013 11:22:54 AM
   Lease Expires . . . . . . . . . . : Thursday, October 31, 2013 11:22:54 AM
   Default Gateway . . . . . . . . . : 10.0.108.2
   DHCP Server . . . . . . . . . . . : 10.0.105.1
   DNS Servers . . . . . . . . . . . : 216.136.95.2
                                       68.105.28.15
                                       68.105.9.16
   NetBIOS over Tcpip. . . . . . . . : Enabled
I can ping the local VLAN interface, as well as the management VLAN interface, but cannot ping the Firewall, and so cannot get to the Internet.
C:\Users\Adam>ping 10.0.105.2
Pinging 10.0.105.2 with 32 bytes of data:
Reply from 10.0.105.2: bytes=32 time=1ms TTL=64
Ping statistics for 10.0.105.2:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 1ms, Maximum = 1ms, Average = 1ms
C:\Users\Adam>ping 10.0.105.1
Pinging 10.0.105.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.0.105.1:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
To try and solve this, I attempted to enter a static route for the firewall, but was given an error:
DCSW1#conf t
DCSW1(config)#ip route 10.0.105.1 255.255.255.255 10.0.105.2
Gateway cannot be one of the addresses configured on this device.
DCSW1(config)#
Problem 2, I am not sure how to fix since I do not have any routing on the firewall that points to these subnets, and therefore is not performing this routing. This routing must be happening on the Cisco switch itself.
I need to set this up to where VLAN 2 and VLAN 3 cannot talk to each other.
Below is an example of a ping test from a computer on VLAN 2 to a computer on VLAN 3
C:\Users\Adam>ping 10.0.109.208
Pinging 10.0.109.208 with 32 bytes of data:
Reply from 10.0.109.208: bytes=32 time=5ms TTL=127
Reply from 10.0.109.208: bytes=32 time<1ms TTL=127
Reply from 10.0.109.208: bytes=32 time=1ms TTL=127
Ping statistics for 10.0.109.208:
    Minimum = 0ms, Maximum = 5ms, Average = 1ms
C:\Users\Adam>
Any help with either of these problems would be appreciated. Thank you.
ok what I proposed indeed will prohibit your vlans to talk with the firewall and the internet, I didn't read carefuly you post and I answered too quickly.
Now you have a L3 switch so the intervlan routing should be done on it and if you want your vlans not to talk with each other except vlan 1 to get to the firewall you can put an ACL inbound on the vlan interfaces and deny communication to other vlan and permit communication to vlan 1.
just put back a subnet static route for each vlan on the firewall and it should be working then if this time I understood your problem correctly.
put your vlan interface on the switch as the default gateway for hosts in each corresponding vlan and put a static default route to the firewall on the switch.
If you want the configs then post  then ask and I'll provide it.
Alain
Thank you so much, if you could help me with the configs that would be awesome. I'm still fairly new to Cisco and have only worked on them minimally. This is my first time with a Layer 3 routing. I've only worked with layer 2 Cisco switches in the past.
Again thank you.
permit ip any any
permit ip any any
int vlan2
int vlan3
Alain
Thanks so much for the help, but now I have another problem. The command to assign the access group does not work. I was able to create the access lists (although it would not take numbers so I had to use vltwo for the name instead). But when I go to add the access-group I get the following:
DCSW1(config-if)#
DCSW1#conf t
DCSW1(config)#int vlan 2
DCSW1(config-if)#ip access-group vltwo in
% Unrecognized command
DCSW1(config-if)#
Any ideas? Is it just this model that can't perform that function? I'm using an SG300-52.
Thanks.
Alain
