Strange PING result...
jquintard
A little part of my conf :
interface GigabitEthernet0/1.101
description Public network
ip address 11.22.33.44 255.255.255.0
interface GigabitEthernet0/1.110
description Private network
encapsulation dot1Q 110
ip address 192.168.0.1 255.255.0.0
router bgp 12345
network 11.22.33.44 mask 255.255.255.0
When I ping :
ping 192.168.0.10 source 192.168.0.1
ping 192.168.1.128 source 192.168.0.1
ping 192.168.0.10 source 11.22.33.44
ping 192.168.1.128 source 11.22.33.44
Why ? I dont understand...
Jerome
5 Replies 5
Harold Ritter
Hi Jerome,
It probably means that host 192.168.1.128 does not have a default GW (or wrong default GW) configured.
The host have two interfaces. One with 11.22.33.55/24, a second with 192.168.1.128/24. 11.22.33.44 is use as default route. If I ping 192.168.0.1 no problem. If I try to connect on 192.168.0.100 : No route to host.
Hi Jerome,
There is quite a bit of missing information.
What type of OS is host 192.168.1.128?
What is the reason the router has a /16 as subnet mask and the host as a /24?
Why is host 192.168.1.128 dually connected?
Can you please provide a snapshot of the routing table for 192.168.1.128?
Does host 192.168.0.100 have a default GW? If so, is it 192.168.0.1?
acampbell
Looks like the router for device 192.168.1.128 does not have a route to 11.22.33.44
I dont see any mention of the network for 192.168.1.128 in the config you have shown
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
192.168.1.128 is include in 192.168.0.0/16. Not ?
