How to find out conflicted IP in a Switch
sudeesh79
Hi all
If an Ip address conflict occurs ,Is there any way (command) to find out from the Switch , that the conflicted Ip address (PC) are connected to which port on that Switch .
Sudeesh
ankbhasi
Hi Sudeesh,
There is no direct command which can let you the port number on a switch but definetely there is way. If you know the conflicting ip address then you can go to the first layer 3 device or first layer 3 hop for that network and do "sh ip arp " and get the mac address and once you get the mac address you can come back to that switch and run a command "sh mac-address-table address " and get the port detail.
Ankur
*Pls rate all helpfull post
ankbhasi
Hi Sudeesh,
Ankur
Hi Ankur
Thanks for your information
Sudeesh S
