LAN Broadcast
amitkaushik24
We have three locations, all are connected trought lease line. One site sometimes facing the problem when they are acces the application from head off. I think this 1pcs braodcasting more.FROM ROUTER END WE WANTS TO CHECK, IS THERE ANY COMMAND TO IDENTIFY WHICH PCS IS BROADCASTING MORE.
regds
AK
5 Replies 5
mahmoodmkl
Level 11
Level 11
Enable IP Accounting under u r lan interface on the router.
Mahmood
How we can enable IP accounting in our LAN interface of router. How we identify.....which pc is broadcasting. Tell me the commans.
Regds
AK
U need to enable it in u r router.
router(config)#int e0/0
router(config-if)#ip accounting
router(config-if)#end
router#show ip accounting
when u issue the above command u can see the ip address of the systems which are forwarding to u r default-gateway.so from here u can check for the ip address which is sending more packets.
Mahmood
Hello
Yes, additionally this command mesures ip traffic only on outbound basis. and router generated traffic is not measured by this.
regards
Dhaval
Hi Friend
You could also try net flow to get the traffic statistics and use application like netflow analyser to get a graphical views.
ip flow-export version 5
ip flow-export destination x.x.x.x 9996
interface fa 0/0
ip route cache-flow
You can download a 30 day trial version of netflow from the following location
http://manageengine.adventnet.com/products/netflow/index.html
HTH, rate if it does
Narayan
