How to find router CPU clock-speed
RanilG
Level 3
Level 3
I need to find the CPU clock-speed of an ISR.
show version does not indicate this information on the c2811 I have running on an SP services IOS image.
Couldn't even locate this on 2800 series feature comparison given in,
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/ps5882/product_data_sheet0900aecd8016fa68_ps5854_Products_Data_Sheet.html
Thanks in advance for your time.
The performance metric is compared by router models not CPU. It's not like you can purchase a router and have the option to upgrade the CPU for faster performance.
The performance metric by router models is explained on the document I pointed out.
What more information do you want than the one provided by the PDF?
__
Edison.
Edison Ortiz
From what I understand, CPE CPU specification information is no longer published as its deemed Cisco
Systems proprietary information, which includes CPU speed, make or any other
architecture information that is requested as part of the requirement.
To gauge the speed of the processor, you can rely on the 'router performance' PDF
http://www.cisco.com/web/partners/tools/quickreference/index.html
HTH,
__
Edison.
Thanks for the information Edison.
In that case don't you think that there should be some sort of CPU related performance metrics available for clients to be able to decide on the correct platform?
Also could you provide more information on router performance metric please?
__
Edison.
Thanks Edison, I will refer to competitive information and other references, relevant to particular technical considerations I have.
