How to find sender,receiver and DR in multicast Router
mahesh18
Level 6
Level 6
Hi Everyone,
On Cisco 2811 which is running pim in sparse mode which command I can use to find sender of traffic?
receiver of traffic ?
and Designated router?
Mahesh
2 Accepted Solutions
Reza Sharifi
Hi Mahesh,
Here is good doc for using multicast troubleshooting commands:
http://www.cisco.com/c/en/us/support/docs/ip/ip-multicast/13726-57.html
Hi Mahesh,
PIM is protocol which is enabled on Layer 3 routing interfaces,
IGMP required on layer 2 switch where user is connected,
IGMP:
if you go on layer two switch where is the client connect and apply the command "show ip igmp snooping groups" you will see the connected client and connected interface and receiving stream from multi casting group address.
"Show ip mroute"  table will tell you that RPF reverse path neighbore and just follow the RPF and you will be able to see end to end path of multi casting path for any igmp group.
For more info visit below link.
http://www.cisco.com/c/en/us/td/docs/ios/solutions_docs/ip_multicast/White_papers/mcst_ovr.html
Tayyab
*** Please rate all helpful responses and mark solutions***
Reza Sharifi
Hi Mahesh,
Hi Mahesh,
IGMP:
Tayyab
Many thanks!
MAhesh
