How to fix Cisco Switch 2960x - Auto reboot
bikrambhujel
I am getting the following error on how to recover the image, please help me.
Xmodem file system is available.
Base ethernet MAC Address: 04:6c:9d:7c:79:00
The password-recovery mechanism is enabled.
USB EHCI 1.00
USB EHCI 1.00
USB Console INIT
Initializing Flash...
mifs[5]: 13 files, 1 directories
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 867840
mifs[5]: Bytes available : 938496
mifs[5]: mifs fsck took 1 seconds.
mifs[6]: 2 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 1146880
mifs[6]: Bytes available : 2723840
mifs[6]: mifs fsck took 1 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[7]: mifs fsck took 0 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 0 seconds.
mifs[9]: 534 files, 136 directories
mifs[9]: Total bytes : 122185728
mifs[9]: Bytes used : 106713088
mifs[9]: Bytes available : 15472640
mifs[9]: mifs fsck took 75 seconds.
...done Initializing Flash.
Loading "c2960x-universalk9-mz.152-4.E7newfirmware.bin"...c2960x-universalk9-mz.152-4.E7newfirmware.bin: no such device
Error loading "c2960x-universalk9-mz.152-4.E7newfirmware.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c2960x-universalk9-mz.152-4.E7newfirmware.bin"...Verifying image flash:/c2960x-universalk9-mz.152-4.E7newfirmware.bin......................................................................................................................................................................................................................................................................................................................................................................................Image passed digital signature verification
File "flash:/c2960x-universalk9-mz.152-4.E7newfirmware.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(4)E7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 18-Sep-18 13:07 by prod_rel_team
Initializing flashfs...
Using driver version 4 for media type 1
mifs[7]: 13 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 867840
mifs[7]: Bytes available : 938496
mifs[7]: mifs fsck took 1 seconds.
mifs[7]: Initialization complete.
mifs[8]: 2 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 1146880
mifs[8]: Bytes available : 2723840
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 1 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 0 seconds.
mifs[10]: Initialization complete.
mifs[11]: 534 files, 136 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 106713088
mifs[11]: Bytes available : 15472640
mifs[11]: mifs fsck took 2 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not needed(v)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
extracting front_end/front_end_ucode_info (43 bytes)
Waiting for Stack Master Election...
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: Failed PortPhyLoopback Packet Test asic_index 0 port_hardware_index 6
POST: Failed PortPhyLoopback Packet Test asic_index 0 port_hardware_index 8
POST: PortASIC Port Loopback Tests : End, Status Failed
Error: ASIC/PHY POST failed. Cannot continue.
%Software-forced reload
07:19:14 UTC Wed Mar 2 2022: Unexpected exception to CPUvector 2000, PC = 3673B84
-Traceback= 0x3673B84z 0x30C49F0z 0x3141118z 0x28CF2ECz 0x28CF4C8z 0x28CF640z 0x629774z 0x6299E4z 0x3675164z 0x3670E60z
Writing crashinfo to flash:/crashinfo_ext/crashinfo_ext_195
=== Flushing messages (07:19:26 UTC Wed Mar 2 2022) ===
Buffered messages:
Queued messages:
Mar 2 07:19:26.878: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar 1 00:01:03.687: Read env variable - LICENSE_BOOT_LEVEL =
*Jan 2 00:00:00.150: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960x_lanbase Next reboot level = lanbase and License = lanbase
Mar 2 07:18:30.090: in Switch 0. Cannot read pid from Flexstack module
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x02F0DCE8 SRR1 = 0x00029200 SRR2 = 0x03673B84 SRR3 = 0x00029200
ESR = 0x00000000 DEAR = 0xEF6F7BFB TSR = 0x84000000 DBSR = 0x01000000
CPU Register Context:
Vector = 0x00002000 PC = 0x03673B84 MSR = 0x00029200 CR = 0x39000093
LR = 0x03673B1C CTR = 0x005FF6E4 XER = 0xC000003B
R0 = 0x03673B1C R1 = 0x07CF2EF0 R2 = 0x00000000 R3 = 0x0497D800
R4 = 0x00000000 R5 = 0x00000000 R6 = 0x00000000 R7 = 0x00000025
R8 = 0x00000000 R9 = 0x04F80000 R10 = 0x04F80000 R11 = 0x00000000
R12 = 0x39000099 R13 = 0x1F183944 R14 = 0x00629988 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x00000001 R27 = 0x00000002
R28 = 0x04EC6614 R29 = 0x00000000 R30 = 0x07CF2F28 R31 = 0x00000000
Stack trace:
PC = 0x03673B84, SP = 0x07CF2EF0
Frame 00: SP = 0x07CF2F00 PC = 0x03673B1C
Frame 01: SP = 0x07CF2F20 PC = 0x030C49F0
Frame 02: SP = 0x07CF2F80 PC = 0x03141118
Frame 03: SP = 0x07CF2F90 PC = 0x028CF2EC
Frame 04: SP = 0x07CF2FB0 PC = 0x028CF4C8
Frame 05: SP = 0x07CF2FC8 PC = 0x028CF640
Frame 06: SP = 0x07CF2FF8 PC = 0x00629774
Frame 07: SP = 0x07CF30F8 PC = 0x006299E4
Frame 08: SP = 0x07CF3100 PC = 0x03675164
Frame 09: SP = 0x00000000 PC = 0x03670E60
Switch uptime is 2 minutes, 4 seconds
cisco WS-C2960X-48FPS-L (APM86XXX) processor (revision J0) with 524288K bytes of memory.
Processor board ID FCW1935A1YB
CPU rev: B
Board rev: 18
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff.../
USB EHCI 1.00
USB EHCI 1.00
USB Console INIT
mifs[5]: mifs fsck took 0 seconds.
mifs[9]: 535 files, 136 directories
mifs[9]: Bytes used : 106938880
mifs[9]: Bytes available : 15246848
executing...
cisco Systems, Inc.
Bikram Bhujel
marce1000
 - Check this thread :  https://community.cisco.com/t5/switching/unexpected-exception-to-cpuvector-2000-after-upgrading/td-p/3413969
 M.
Leo Laohoo
Contact Cisco TAC and organize an RMA.
The switch is dead.
