How to fix my destination unreachable when i try to ping dns server
kherrolyeseru
the problem start after table 6.3.It should say request time out but i got destination are unreachable i already make a new one almost 2 time but still facing the same problem.And when i try to skip it,i stuck at step 17.thera are no ip nat display.can someone fix my problem.I have to send my this assignment in a few days.
https://drive.google.com/file/d/12Fuwe74Q0Nw-j46OwK-TsoQ_mtNiWt-1/view?usp=sharing    (my file)
5 Replies 5
post the zipped Packet Tracer project (.pkt) file...
here
the main problem was the DHCP pool on the ISP router (network 127.0.0.0/8 instead of 128.0.0.0/8) which caused the Home router not to get an IP address at all.
I have also added the NAT configuration to to the Home router.
There is a typo in the instructions: At item 15., it says you should configure 'access-list 1 permit' followed by the suggested wildcard mask, 0.0.0.255. Since the actual Z network has a /16 mask, the correct wildcard mask must be 0.0.255.255.
Sometimes they build these 'mistakes' in in order to get you thinking. Either way, it might be a good idea to tell your instructor about it.
Attached the revised file (saved in Packet Tracer version 8).
FIXED,THANK YOU SO MUCH FOR THE HELP
glad to help !
