07-24-2018 12:02 PM - edited 03-08-2019 03:44 PM
Can you help me if i can stack ( WS-C3850-48P-S ) with ( WS-C3850-12X48U-S )
Solved! Go to Solution.
07-24-2018 01:07 PM
StackWise-480 supports a mixed stack of any Catalyst 3850 models (48 ports 10/100/1000, 24 ports 10/100/1000, and 12/24 Ethernet SFP ports; see Figure 1). You can mix the switches with different number of access ports (48, 24, and 12), different type of access ports (copper and fiber, PoE, and non-PoE-capable), and different network modules. But all switches in one stack must have the same version of IOS XE and the same feature set license. A mixed stack of LAN base switches with IP base or IP services is not supported. Catalyst 3850 Series Switches with a LAN base feature set can only stack with other Catalyst 3850 Series LAN base switches. The same applies to IP base and IP services as well.
Check the below guide :
BB
=====️ Preenayamo Vasudevam ️=====
07-24-2018 01:27 PM
07-25-2018 04:53 AM
07-24-2018 01:07 PM
BB
07-25-2018 04:53 AM
07-24-2018 01:27 PM
