how to get Call-home to work via proxy on a Cat 9200
EddyFonseca3815
Hello All
I have created a Proxy for the Smart Lic and I am testing this on a 9200 Switch.  I have enable the following command and waiting to see if they switch will send the Http request to the proxy server.  Since this is the only device I have set to send to this proxy I should only see this traffic but I am not.
I have used the steps notes in this url " https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/software/release/16-12/configuration_guide/sys_mgmt/b_1612_sys_mgmt_9200_cg/cisco_smart_licensing_client.html#concept_o2x_fvp_qgb " and I also have set the following commands
ip http client source-interface Vlan105
ip http client proxy-server 10.32.68.31 proxy-port 3128
call-home
contact-email-addr sch-smart-licensing@cisco.com
http-proxy "10.32.68.31" port 3128
profile "test-proxy-srv"
reporting smart-licensing-data
destination transport-method http
no destination transport-method email
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
I have looked at the " show license eventlog " to see if there is a reason why I am not getting the traffic to flow via the proxy but
2023-09-25 13:28:06.840 CDT SAEVT_INIT_SYSTEM_INIT
2023-09-25 13:28:07.847 CDT SAEVT_INIT_CRYPTO success="False" error="Crypto Initialization has not been completed"
2023-09-25 13:28:37.847 CDT SAEVT_INIT_CRYPTO success="True"
2023-09-25 13:28:37.851 CDT SAEVT_COMM_RESTORED
2023-09-25 13:28:37.922 CDT SAEVT_INIT_COMPLETE
2023-09-25 13:29:32.982 CDT SAEVT_COMM_FAIL error="Unable to resolve server hostname/domain name"
2023-09-25 13:29:34.157 CDT SAEVT_UTILITY_REPORT_START
2023-09-25 13:29:37.848 CDT SAEVT_PRIVACY_CHANGED enabled="True"
2023-09-25 13:51:01.299 CDT SAEVT_CONFIG_PERSISTED
I am able to ping tools.cisco.com without issue but I do not see this traffic going to the out or am I missing something.
92K-CON6#ping tools.cisco.com
Sending 5, 100-byte ICMP Echos to 72.163.4.38, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/33/36 ms
92K-CON6#
If you can tell me what I could be missing or a command I need to run to ID the issue .
thank you
0 Replies 0
