Showing results forĀ
Search instead forĀ
Did you mean:Ā
How to get info by looking at part no ?
mirehteshamali
HI all ,
I am just confused which part no to order . most of them are similar.
for example
WS-C3560-24TS-S
WS-C3560-24TS-E
WS-C3560-24PS-S
WS-C3560-24PS-E
WS-C3560G-24TS-S
WS-C3560G-24TS-E
i would like to know how to interpret features by looking at a perticular part no .. like  G refers to Gigabit , P refers to POE etc . what does T , S , E refers to ?
Leo Laohoo
"T" stands for 10/100/1000BaseTx or NON-PoE
"S" stands for Standard multi-layer switch image or Layer 2 IOS only;
"E" stands for Enhanced mulit-layer switch image or Layer 3 IOS
sdheer
Hi ,
you can retrieve info on all the feature supported by these switches from the link below:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html
Swati
Please rate if you find the post helpful
Leo Laohoo
