06-25-2015 09:04 PM - edited 03-08-2019 12:43 AM
Is there any technique to identify 3550/3560 support intervlan routing or not?
06-25-2015 10:35 PM
It does support Intervlan routing.
you can check the following guide:-
http://www.cisco.com/c/en/us/support/docs/lan-switching/inter-vlan-routing/41260-189.html
Else,
Login to the box and try to configure the ip routing command and then try to confiugre the SVI interfaces.
Inayath
**Please do not forget to rate the post if this info is helpfull.
06-25-2015 11:49 PM
Enable routing on the switch by using the “ip routing” command.
Even if IP routing was previously enabled, this step ensures that it is activated.
Switch(config)#ip routing
Note: If the switch does not accept the ip routing command, upgrade to either SMI image Cisco IOS Software Release12.1(11)EA1 or later, or an EMI image, and repeat this step. See the Pre requisites section for more information.
Check the "show run" command to Verify whether “ip routing” is enabled. The command, if enabled, appears towards the top of the output.
hostname Switch
ip subnet-zero
ip routing
Khaleelur Rahman
