how to identify DRAM and Flash memory of a individual member from a switch stack
tusharp81
I want to check DRAM and Flash of each member in a stack . How can I verify the same .
InayathUlla Sharieff
HI Tushar,
To determine the amount of Flash and DRAM, issue the show version command. Refer to the bold text in the output below. DRAM is divided logically, combining the two numbers to determine total DRAM. In this case, it is 45056K/4096K bytes (45056kB + 4096kB = 49152kB), which is equal to 48MB.
router>show version
IOS (tm) C2600 Software (C2600-JS56I-M), Version 12.1(5)T9,  RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Sun 24-Jun-01 15:29 by cmong
Image text-base: 0x80008088, data-base: 0x8149F218
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
R1 uptime is 9 weeks, 3 days, 2 hours, 32 minutes
System image file is "flash:c2600-js56i-mz.121-5.T9.bin"
cisco 2651 (MPC860P) processor (revision 0x200) with 45056K/4096K bytes of memory.
Processor board ID JAB04390J7N (1507969529)
M860P processor: part number 5, mask 1
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
2)
To check on all the switches of Stack two way:
1- session 4 >> to login to the 4th switch of the stack.
2- remote command all show ver >> this will give us show version output of all switches.
Inayath
*Plz rate if this info is usefull.
remote
Andrew Clark
To quickly look at flash you can do
sh flash1: (for the first switch in the stack)
sh flash2: (for the second switch in the stack)
sh flash3: (for the third etc...)
other than sh ver for the DRAM i'm not sure if there is an easier way.
