02-01-2017 05:06 AM - edited 03-08-2019 09:08 AM
Dear Friends,
Thanks in advance.
Actually
request to share your knowledge on this.
Rahul
Solved! Go to Solution.
02-01-2017 05:20 AM
Often you can define an ACL to match traffic, allowing it, and then look at the ACL counters. They should work fine on a 7200, not as sure about a ASR9K, as the latter probably has special hardware to support ACLs, and matches might not be reflected when you show the ACL. If not, there may be additional commands to get match stats otherwise.
Also on a 7200, again not sure about the ASR9K, if NBAR is supported, you can use that for matching in CBWFQ class-maps. They too should have match count stats. The advantage of NBAR, it might match WEB traffic not using port 80 or Torrent traffic not matching its usual ports.
02-01-2017 05:20 AM
