How To Load An Image Using TFTP Server on Cisco 2690-G Switch
Kindly share the procedure of How to load an IOS into 2960-G switch's flash: using TFTP server only when it is missing valid IOS from its flash.
I need information such as how to assingn IP address etc.
Thank You!
2 Accepted Solutions
Leo Laohoo
You mean the switch is currently in ROMmon or not?
If the 2960 is in ROMmon, then go read (and understand) this process FIRST and then go HERE and jump immediately to section 4a.
How can you use TFTP when your switch does not know IP?
You need XModem.
7 Replies 7
Reza Sharifi
follow this link:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/41542-191.html#concept7
Leo Laohoo
I have understood the process.My only query is instead of xmodem cant we use TFTP here?
You need XModem.
It is very helpful.Thank you 4 ur time and help.
Mitesh Manwatkar
Can you then please mark this thread as "Answered"?
Hi...
Thanx 4 d reply...It was very helpful.
can u help me related with port security issue..kindly follow the below link.
https://supportforums.cisco.com/discussion/12197626/mac-address-not-getting-sticked
Regards.
