how to migrate switch AP from WLC to other WLC
fernandezj
I try to remplace WLC  because the old wlc (7.0) is capacity full...
but the AP (3502) do not "registered" to new WLC (7.3)....
If you have a idea, without make a reset factory to AP...
Best regards
Gregory Snipes
Level 4
Level 4
You will need to update option 43 to point to the new WLC on the DHCP server subnet that serves the VLAN that the new AP is in.
glen.grant
   Just change the ip address of where the AP is pointed  to the new primary controller address . It should then reassociate to the new controller .
Go To WLC
Then Select Wireless
Select AP
Select High availability Tab
There will be Primary and Secondary Controller
If you want you app to select Primary Controller give that ip
and if u want to assing secondary controller give that ip.
*** Do Rate Helpful Posts***
Jawad
