How to monitor 2950 switch
holunking
Dear all,
How to monitor 2950 switch after reload ?
Pls advise
Stanley
mahesh-gohil
At time of booting u can see output to console only so connect using console and see output
However, make sure the logging console level is set as desired and that logging has not been disabled with the no logging console command
And after booting u can use various debug command . to see output of debug command on vty use term monitor command in priviledge config mode
Mahesh
Dear Mahesh,
Thanks you your reply, but there have any quick commad to check the switch status?
Stanley
means
what exactly u want to know about switch
whether u want to know link up-down or anything else
and do u want it from console or from vty?
pl. reply
mahesh
