How to prioritize traffic?
CTS-Tech1
We need to give TCP 3389 & 3399 priority over all other traffic between a Cisco 1941 and 2951.
What is needed to do this?
6 Replies 6
John Blakley
You'll need to configure qos on both of your routers. Apply the policy outbound on both interfaces.
access-list 101 permit tcp any any eq 3389
access-list 101 permit tcp any any eq 3399
class-map match-any Policy
match access-group 101
policy-map Policy
class Policy
priority percent 10
int fa0/0 (wan interface)
service-policy output Policy
Do this on both sides. The problem with giving priority is 2 fold. On one hand, you're guaranteed a minimum of 10 percent of your total reservable bandwidth. Total reservable is 75% of your link speed. If you have a T1, your link speed is 1544 with 1158k usable. Ten percent of that would be 115k that you would be guaranteed for this traffic, BUT it's also your maximum in times of congestion because LLQ also polices the traffic at that guaranteed rate to mitigate starvation of other queues.
Another way that you could do this is to give a bandwidth guarantee and then shape the traffic in the same queue. This would give the same effect, but you would have a little more control as to how high of a ceiling to give:
policy-map Policy
class Policy
bandwidth percent 10 ( minus any existing priority queues; if none exist, then you're back at 115k)
shape average 500000 (shape at 500k)
Above would guarantee 115k and cap it at 500k.
HTH,
John
HTH, John *** Please rate all useful posts ***
If possible, we would like TCP 3389 & 3399 traffic to have priority over all other traffic - and use up to 50% of the bandwidth.  But we would also like the other traffic to be able to use 100% of the bandwidth if no TCP 3389 & 3399 traffic exists.
Will this do what we need it to do, if applied to the outside interface of both Routers?
class-map match-all PRIOR1
match access-group name PRIOR
policy-map PRIOR2
class PRIOR1
priority percent 50
interface GigabitEthernet0/1
service-policy output PRIOR2
ip access-list extended PRIOR
permit tcp any eq 3389 any
permit tcp any eq 3399 any
Hey CTS,
it would do what u said there, but 50% for priority is somewhat a very high value, keep in mind that priority traffic not only uses up to 50% of the bandwidth, but its also gets time sensitive and low latency service, which may have great negative impact on the other trfic flows.
depends on ur equipment, you may need to add the class-default under the policy-map:
policy-map PRIOR2
class PRIOR1
  priority percent 50
class class-default
  fair-queue
  bandwidth remaining percent 100
HTH,
Soroush.
Hope it Helps!
Soroush.
Is this traffic going over the WAN link? if so you will need to use some markings along with the priority statement and your service provider should honour those markings.
policy-map PRIOR2
class PRIOR1
  priority percent 50
  set ip dscp af41
class class-default
  fair-queue
Siddhartha
Thanks guys.  This is for a dedicated point-to-point connection with 10Mbps.
Just to clarify - does this need to be applied to the inside & outside interfaces - or just the outside?
Hi CTS,
on the outside only in this case. however, generally your need is telling you in which direction you want to apply it.
Alessio
