how to remove 4500x vss configurations
samir khoury
I am having issue with upgrading the IPbase 4500X to VSS. I like to know how to remove all the VSS configurations and reset the switches by to factory default.
I had many issue configuring vss on 4500X with different license (ipbase, Enterprise).
thanks
2 Accepted Solutions
Reza Sharifi
You need to have the same license on both 4500x switches in order to form VSS.  As for changing the mode to stand-alone you can simply convert from VSS to stand-alone and delete the rest of the VSS configs.
Ganesh Hariharan
thanks
Hi Samir,
Check out the below link under converting active VSS  /Standby switch to standalone switch. It has given good explanation along with command to convert.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1-2/XE_340/configuration/guide/config/vss.html#wp1056162
Hope it Helps..
-GI
Rate if it Helps..
Reza Sharifi
thank you guys,
You are all correct,
after I posted my question. I went back and thought the license have to match, which was my argument with my colleagues.
I did make sure both switches have the same license. and the IOS. and figured that to remove the VSS configuration was simply to issue the command (switch virtual mode standby). I feel I wasted so much time needlessly on this, but finally things worked out just in time to continue with my project.
once again thank you.
Ganesh Hariharan
thanks
Hi Samir,
Hope it Helps..
-GI
Rate if it Helps..
