How to remove telnet on Nexus 7000
rfuentes1111
Hi Team,
I have a project to get done we are planning to disable Telnet and enable SSH on a Nexus 7000.
Can someone help out with this i need to know the command to remove telnet and only have SSH.
Also I now this is another Topic but i have a VPC that it was use before and i want to use it again, but i want to remove the following command.
how can i do it thank you team. and by removing this need to know if it going to create an issue.
Switchport access vlan4
interface port-channel5
switchport
switchport mode trunk
switchport access vlan 4
switchport trunk native vlan 4
vpc 5
ahmedshoaib
Level 4
Level 4
Hi;
1) To disable the Telnet on Nexus 7000, is just need to disable the telnet feature:
no feature telnet
2) To remove the Switchport access vlan4 is simple as we are removing on normal Cisco switch & there will be issue:
 no switchport access vlan 4
Thanks & Best regards;
