how to reset a pix 501
carl_townshend
Hi all,Can anyone tell me how to reset a pix 501 to factory defaults ?
amit-singh
Level 8
Level 8
Hi Carl,
Use "configure factory-default" command once you are in enable mode.
HTH,
-amit singh
What if I do not have the password for this device ? how do I reset then, is there a rommon mode ?
Yes, Carl there is a rommon mode called as monitor mode. Reboot the pix and press esccape key, you will fall in the monitor mode. But I am not sure that you can set the pix on factory-default while in monitor mode.
You can do a password recovery on PIX and then set it up on the factory-default if you want. Please check the link below for password recovery.
http://www.cisco.com/warp/public/110/34.shtml
HTH,Please rate if it does.
-amit singh
