How to reset password of Catalyst C9200 switch?
AwaisAhmad44463
Can anyone kindly guide on how to reset the password of C9200 switch?
thanks.
TJ-20933766
Unplug the power from the switch. Hold the Mode button and reapply power. Hold the button till the Status LED turns amber. On the console you should be in the Boot Loader and your command prompt should look like this:
Switch:
Type the following commands:
Switch: SWITCH_IGNORE_STARTUP_CFG=1
Switch: boot
Once the switch has booted you can copy the saved config back into the running config.
Switch# copy start run
Then set your password and then remove the "ignore startup config" setting.
Switch# username ME priv 15 secret MYPASSWORD
Switch# no system ignore startupconfig switch all
Then save your new config
Switch# copy run start
TJ-20933766
Switch:
Switch: boot
@TJ-20933766
Dear Tyson,
Thanks a lot for your response, I will try the shared solution.
Switch:
Switch: boot
Then 9200L will stuck at Username. without that we can use
Dharka
It is coming back to UN after boot command.
