01-23-2011 11:45 PM - edited 03-06-2019 03:09 PM
I having an issue with my router as I accidentally changed the config register to 9600 by accidentally typing confreg 9600 in ROMMON mode so i lost connection through console. Is there any chance to physically do a hard reset my 1841 router? I just bought it on ebay last month. Or is there any possible way to fix it through aux port as my 2 fe ports are intermittent at the monent. I couldn't get any display when I'm setting the speed to 9600 or 115200 and just getting this unknown carachetr like this:
Thanking you guys in advance
Solved! Go to Solution.
01-24-2011 12:20 AM
The 9600 confreg indicate that you set bit values to
15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0
1 0 0 1 0 1 1 0 0 0 0 0 0 0 0 0
which means you set console speed to 1200.
I think if you set console speed to 1200 your console should work
Bit 5 | Bit 11 | Bit 12 | Console Line Speed (baud) |
1 | 1 | 1 | 115200 |
1 | 0 | 1 | 57600 |
1 | 1 | 0 | 38400 |
1 | 0 | 0 | 19200 |
0 | 0 | 0 | 9600 |
0 | 1 | 0 | 4800 |
0 | 1 | 1 | 2400 |
0 | 0 | 1 | 1200 |
Mahesh
01-24-2011 12:20 AM
1 | 0 | 1 | 57600 |
1 | 1 | 0 | 38400 |
1 | 0 | 0 | 19200 |
0 | 0 | 0 | 9600 |
0 | 1 | 0 | 4800 |
0 | 1 | 1 | 2400 |
0 | 0 | 1 | 1200 |
Mahesh
