Problem with config register on 4506 Catalyst
burleyman
Level 8
Level 8
I have a few switches that are having the same problem. I set the config-register to 0x2102 and when the switch boots it goes into ROMMON and I don't understand why. I have to set the config register to 0x101 for it to boot into config mode.
Am I missing something here, I thought the default was 0x2102 and it would boot into config mode.
Here are the show ver and dir of everything.
4506#show ver
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(18)EW2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 01-Nov-04 16:23 by kellythw
Image text-base: 0x00000000, data-base: 0x010BAF04
ROM: 12.1(20r)EW1
Dagobah Revision 90, Swamp Revision 3
4506 uptime is 2 days, 30 minutes
System returned to ROM by reload
System restarted at 11:10:49 EDT Sat Mar 24 2007
Running default software
cisco WS-C4506 (MPC8245) processor (revision 4) with 262144K bytes of memory.
Processor board ID FOX091302B9
Last reset from Reload
1 Virtual Ethernet/IEEE 802.3 interface(s)
96 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
511K bytes of non-volatile configuration memory.
Configuration register is 0x101
4506#dir f bootflash:
Directory of bootflash:/
1 -rwx 10308052 Feb 19 2005 22:42:41 -05:00 cat4000-i9s-mz.122-18.EW2.bin
3 -rw- 12666 Mar 24 2007 11:02:32 -04:00 startup-config
27262976 bytes total (16929204 bytes free)
4506#dir bootflash:
2 -rw- 12666 Mar 24 2007 10:49:24 -04:00 [mem]
4506#dir nvram:
Directory of nvram:/
507 -rw- 3704 <no date> startup-config
508 ---- 27 <no date> private-config
1 ---- 4 <no date> rf_cold_starts
2 ---- 12 <no date> persistent-data
524280 bytes total (518449 bytes free)
4506#dir system:
Directory of system:/
2 dr-x 0 <no date> memory
1 -rw- 12606 <no date> running-config
9 dr-x 0 <no date> vfiles
No space information available
4506#dir cat4000_flash:
Directory of cat4000_flash:/
1 -rw- 556 <no date> vlan.dat
524280 bytes total (523724 bytes free)
Mike
9 Replies 9
Bobby Thekkekandam
Hi Mike,
The main difference between 0x2102 and 0x101 is that 0x2102 will boot the image specified by the "boot system" command whereas 0x101 will boot the first valid IOS image in flash.
The fact that it boots into ROMMON with 0x2102 most likely means that the "boot system" command is specifying an image that is not in bootflash.
HTH,
Bobby
But you can see the IOS image is in the boot flash
Mike
Amit Singh
Mike,
Please paste the output of " show bootvar "
-amit singh
Here it is.....
4506#show bootvar
BOOT variable does not exist
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Thanks for your help.
Mike
Hi Mike,
Set the boot path as
4506(config)#boot system flash bootflash:cat4000-i9s-mz.122-18.EW2.bin
4506(config)#config-reg 0x2102
4506#wr mem
4506#reload
And it should be ok there after.
Ankur
*Pls rate all helpfull post
After I posted what you wanted I figured it out and I realized I needed to do the commands you listed.
Thanks you,
Mike
I am going to try it this weekend and will rate your post after it works.
Mike
Mike,
This will work for you. The reason it was going to rommon because, you dont have any bootvariable set to boot the switch.By changing the rommon to 0x101, it was picking up the first valid image to boot from the flash.
-amit singh
thanks ankbhasi
