how to save running config to startup config
Cnote100
How to save running config to startup config command? after port vlan assignment.
InayathUlla Sharieff
copy running-config startup-config
Wr mem
Inayath
vmiller
Level 7
Level 7
What model  device ?
What version of code ?
Did you look on www.cisco.com ?
Wr mem
Inayath
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
If you're asking about the VLAN information that doesn't appear in a config when running a VTP capable switch in server or client mode, the information is (automatically) stored in a local VLAN database (and shared across trunks with other VTP capable switches running in server or client mode).  For the same VLAN information for a VTP capable switch running in transparent or off mode, saving the running config saves that information too.
