How to set syslog for nexus 7000k without using the loopback option
Imran Asri
Do you guys know how to set syslog using dedicated interfaces instead of using loopback. If yes, can you send a guide or command that i can use to practice this.
p.s (im currently using nexus 7000)
Thank you
But config syslog update source is optional not mandatory in NSK'
If You want  can use any ineterface but you must sure it reachable to server.
May i know how to change from loopback to any interfaces ? Instead of this 0de37249-addf-4eec-b34e-f0d6b73cf1a7.jpg
try logging source-interface e0/0 <<- check if N7K accept it
Imran Asri
alright i will try first but lets say if its not working. Is there any alternative way to do it ?
