Error IOSXE_SYS_INFRA-4-BIPC_RX_IN_APPL_THRESHOLD
dijix1990
I get a error
Apr 11 09:41:01.442: %IOSXE_SYS_INFRA-4-BIPC_RX_IN_APPL_THRESHOLD: Switch 1 R0/0: linux_iosd-image: Number of IPC messages held in the application reached the maximum channel threshold.  IPC channel 'ngwc fed bipc':ipc_ctl_id 55 (ipc_fd 187, seq_num 101), curr IPC msg hel in appl 1001
What does it mean?
Switch Ports Model              SW Version        SW Image              Mode
*    1 53    C9300L-48P-4X      17.06.05          CAT9K_IOSXE           INSTALL
     2 53    C9300L-48P-4X      17.06.05          CAT9K_IOSXE           INSTALL
     3 53    C9300L-48P-4X      17.06.05          CAT9K_IOSXE           INSTALL
     4 53    C9300L-48P-4X      17.06.05          CAT9K_IOSXE           INSTALL
     5 53    C9300L-48P-4X      17.06.05          CAT9K_IOSXE           INSTALL
     6 53    C9300L-48P-4X      17.06.05          CAT9K_IOSXE           INSTALL
     7 53    C9300L-48P-4X      17.06.05          CAT9K_IOSXE           INSTALL
     8 53    C9300L-48P-4X      17.06.05          CAT9K_IOSXE           INSTALL
My contract is over, I downgraded one of my stacks and it helped
9 Replies 9
Mark Elsen
  - Use latest advisory release https://software.cisco.com/download/home/286322089/type/282046477/release/Bengaluru-17.6.5
                            (if applicable) , check if that can help ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
But I already use it. It's in my post
balaji.bandi
Is the error after the upgrade? check the below explanation for that error - may help you :
%IOSXE_SYS_INFRA-4-BIPC_RX_IN_APPL_THRESHOLD : Number of IPC messages held in the application reached the maximum channel threshold. IPC channel '[chars]': ipc_ctl_id [dec] (ipc_fd [dec], seq_num [dec]), curr IPC msg hel in appl [dec]
Explanation Application is holding large number of received IPC messages
Recommended Action Copy the error message exactly as it appears on the console or in the system log. Perform a search of the Bug Toolkit (https://bst.cloudapps.cisco.com/bugsearch/). If you still require assistance, open a case with the Technical Assistance Center via the Internet (https://mycase.cloudapps.cisco.com/case), or contact your Cisco technical support representative and provide the representative with the gathered information.
BB
Yes, after upgrade from 17.3.4. I've checked it, there's nothing
dijix1990
It happens on my eight staks and there isn't on the standalone switches. All of them were upgraded to 17.6.5
                                >...All of them were upgraded to 17.6.5
                   Then it is advisable to escalate the problem = contact TAC
 M.
       Beauty and terror
      Just keep going
       No feeling is final
if this issue occurring after the upgrade, then i got to TAC for assistance or if this is effecting the environment, i downgrade to fix the issue.,
BB
Then that could be the bug
we are running 17.6.3  - the same models I do not see any issue.
BB
