How to setup Vlan for iSCSI
nileshchavan
I am trying to setup Vlan for iSCSI, by using cisco switch 3560G.
And i also want to establish a trunk for separating the iSCSI traffic.
Plz help me to make this setup.
Nilesh
Ganesh Hariharan
Nilesh
Nilesh,
Check out the below link for vlan configuration and trunking on cisco switches
http://www.ciscopress.com/articles/article.asp?p=29803
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Here is the port channel and interface configurations..
You will need to make the ports LACP and that is described with the Channel-group mode ACTIVE
(active meaning lacp)
Configure the ports....
interface GigabitEthernet3/1
description To ISCSI
switchport mode trunk
channel-group 1 mode active
interface GigabitEthernet3/2
Configure the Port channel...
interface Port-channel1
description ISCSI
switchport
Please rate....
