How to setup vlans and routing between them
mansours1002
Hey guys
I am onboard a vessel where I have a Cisco 1921 router with intergrated 8-port dwitch. I have no experince what so ever with Cisco, onlye knowledge about netwrok in general.
What I need to do is to create 3 VLANs wit different networks and thier own gateways internally( no external routers, no external switches), and I want client in all networks to be able to communicate qith each other:
Vlan 2:
192.168.0.0
Default Gateway: 192.168.0.1
Network Mask: 255.255.255.0
Vlan 3:
192.168.1.0
Default Gateway: 192.168.1.1
Vlan 4:
192.168.2.0
Default Gateway: 192.168.2.1
As mentioned abode, I need clients from each VLAN to be able to communicate with each other. Se drawing
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
It might be as simple as defining VLAN interfaces for your 3 VLANs, and they assigning the ports to one of the 3 VLANs.
usasigcis
you may have to create bvi to make it work.
