How to stop on-going IOS tftp transfer?
sirajmuneer
Team,
are there any IOS commands that can be used to stop/kill/halt IOS image transfer via TFTP ?
thanks
If you are telneting to that device via the port you are planning to shut down, you need to be careful thus I understand your concern :)
If the key combination isn't working as suggested, you can apply an ACL to the interface facing the TFTP server.
ip access-list extended KILL-TFTP
deny udp any eq 69 any
permit ip any any
interface xxx
ip access-group KILL-TFTP in
HTH,
__
Edison.
11 Replies 11
Jerry Ye
Have you tried Ctrl-^ ( = Ctrl Shift 6).
HTH,
jerry
this works for me. great.
thanks ... ctrl shift 6 works like a charm
Lucien Avramov
Level 10
Level 10
IF you are already telnetting in during the transfer and see the transfer on the screen, use CTRL+SHIFT+6+X (= CTRL^X)
If you are not seing the transfer and it happens on someone else's Telnet window, then you can telnet to the router and flap the interface with shut/ no shut to kill it
i did tried ctrl+z and CTRL+SHIFT+6+X few times, with no luck.
is there any other way other than shut/no shut the port?
thanks
How about killing the TFTP server daemon?
jerry
i do have tftp server access and it is a UNIX box. not sure how to kill tftp job using UNIX command and of course it is out of this forum's scope.
You can edit the file /etc/inetd.conf or /etc/inet/inetd.conf, and comment out the following line like this
#tftp dgram udp wait root /usr/sbin/tcpd in.tftpd
Then restart the inetd like this
pkill -HUP inetd
HTH,
jerry
telnet to the router from another window and bounce the link, if you dont have access to the TFTP server itself.
permit ip any any
interface xxx
HTH,
__
Edison.
chinkevi_2
i personally find most pc does not work with Ctrl-^X or Ctrl-z.. i often use Ctrl-6 and it works.
