How to take backup config of n/w devices without using any tool..?
Can any one tell me any methodology / procedure to take config backup of all network devices like Router, Switches, Firewall,Load Balancer etc.
on regular interval of time period wrt hostname and time.
As I found one method, below mention is one method to take backup config to tftp server but still am not sure about how configuration will save ..?
My basic requirment is config should save with hostname and resp date.
Can you suggest me any thing else...!!
Thanks in advance
Backup Configuration to a TFTP Server
This example is to save the running config to a TFTP server (10.1.1.1) every Sunday at 23:00:
Router(config)#kron policy-list Backup
         Router(config-kron-policy)#cli show run | redirect
      tftp://10.1.1.1/test.cfg
         Router(config-kron-policy)#exit
         Router(config)#kron occurrence Backup at 23:00 Sun recurring
         Router(config-kron-occurrence)#policy-list Backup
cadet alain
you can also use the archive feature
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t7/feature/guide/gtrollbk.html#wp1100253
Regards.
Alain.
Here is a sample Archive config that is set to save 10 configs that are gathered once per week to Flash: in a directory called CONFIGS, and saves them with the hostname and the timestamp
Router1#cd flash:
Router1#mkdir CONFIGS
Create directory filename [CONFIGS]?
Created dir flash:/CONFIGS
Router1#
Router1#config t
Router1(config)#archive
Router1(config-archive)#path flash:/CONFIGS/$h$t
Router1(config-archive)#write-memory
Router1(config-archive)#time-period 10080
Router1(config-archive)#maximum 10
Router1(config-archive)#end
Router1#
Mike
