08-26-2015 02:37 AM - edited 03-08-2019 01:31 AM
Hi Frnds,
Can any one suggest me a script to take the backup of the network devices(routers/switches) .Like running-configuration with one go for all the devices.
Thanks ,
Mohammad.
Solved! Go to Solution.
08-26-2015 02:51 AM
Couple of ways you could do this but it needs to be enabled on each device if you don't have something like LMS/Prime to grab all devices configs centrally
Archive command and tftp config to a device on your network
http://www.cisco.com/c/en/us/td/docs/ios/fundamentals/command/reference/cf_book/cf_a1.html#wp1018716
or use a kroon job , schedule it and send it off to a device for storage
just some options there is probably more ways as well
edit
you could use EEM aswell
08-26-2015 02:51 AM
edit
09-16-2015 12:29 AM
Hi Mark,
Apart from the above Kroon , do we have any script which we can take backup by just running a batch file and which can be customized according to our need.
Thanks & Regards,
Shaik Mohammad.
12-08-2022 11:26 PM
yes, we can do. with as below steps.
| 01:- | Create one Folder in D Drive Like D:\Backup\ |
| 02:- | paste putty software inside D:\backup\ |
| 03:- | Create Command File inside backup folder [D:\Backup\command-192.168.1.1.txt] |
| 03:- | Create Command File inside backup folder [D:\Backup\command-192.168.1.2.txt] |
| 03:- | Create Command File inside backup folder [D:\Backup\command-192.168.1.3.txt] |
| 04:- | Enter Command [copy runn | redirect tftp://Backup_192.168.1.1.cfg] inside D:\Backup\command-192.168.1.1.txt |
| 04:- | Enter Command [copy runn | redirect tftp://Backup_192.168.1.2.cfg] inside D:\Backup\command-192.168.1.3.txt |
| 04:- | Enter Command [copy runn | redirect tftp://Backup_192.168.1.3.cfg] inside D:\Backup\command-192.168.1.3.txt |
| 05:- | Create bat file D:\Backup\backup.bat and enter as below command inside bat file |
| write below command in bat file and save | |
| 6:- | putty.exe -ssh 172.25.175.1 -l USER-NAME -pw ENTER-USER-PASSWORD -m D:\Backup\command-192.168.1.1.txt |
| 6:- | putty.exe -ssh 172.25.175.1 -l USER-NAME -pw ENTER-USER-PASSWORD -m D:\Backup\command-192.168.1.2.txt |
| 7:- | Run TFTP software and set the path of backup folder |
| 8:- | open command prompt and run D:\Backup>Backup.bat and it will save running config to tftp |
| But now a dayes. We should use automation tools linke Ansible. |
