how to test and know how many k pps have to set for storm-control in whole network
martlee2
assume 100K
storm-control broadcast level pps 100k
storm-control multicast level pps 100k
storm-control unicast level pps 100k
6 Replies 6
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
To set the "right" storm-control values, you need to know the normal/expected levels for your network, including for expected peaks; doubtful one-size-fits-all.
which command can do this?
where should this command be run?
Disclaimer
Posting
If you mean a command to "analyze" current storm-control needs, I'm unaware of one.
BTW, broadcast levels can be quite different per VLAN.
what is the real practice to guess these values?
Disclaimer
Posting
My guess is, most real practice is to not set the values.
The issue is, such policing can very easily impede legitimate traffic, and unless you have a good analysis, you might not be able to determine the high water mark.  Even if you have a good benchmark, the high water mark might legitimately differ tomorrow.
It's true, you can probably police some legitimate traffic without a too adverse effect, but that too requires careful analysis.  I.e. exactly where is the "too much" division?
Ideally, and in theory, you set such policers to avoid complete meltdown of your network, but that too is difficult to predetermine.
What you could try is searching the Internet for various opinions of how these values should be configured.
http://www.cisco.com/web/about/security/intelligence/network_performance_metrics.htmlthis
web mention the maximum rate is 1000/84/8*1000 = 1488K
should i use 81K or 1488K in the storm setting?
